Hi - I'm moving up from a 25 ft Wellcraft walkaround with a single outboard to a 27 foot Sailfish with twin outboards and am wondering about docking it. To be frank I'm not particularly great at docking the Wellcraft where I have to back in to my finger float. Some days I nail it perfectly, usually when I'm alone and there is no one the pier to see
Other days, not so graceful. Those, of course, are the days the pier is loaded with onlookers...
My particular docking situation is that I motor in with the fingers to port, start a right turn before my slip, usually in neutral, and then back in with my finger to starboard and neighbor's boat to port. More often then not, I end up with the stern where it needs to be but the bow is too far to the left and I have to push off my neighbors rail by hand. (I go slow so I've never hit anything...)
Anyway, is having the two outboards going to help much with docking the Sailfish? I suspect they are mounted too close together to offer the control the big boys have with their twin diesel inboards. Does the propwalk effect provide enough control to back up and dock using only the throttle and shifter controls? Or do you primarily use the steering wheel? Do you have to tilt the motors up first to increase the propwalk effect? The prevailing wind and current are in line with the finger float and usually not a major factor. Any tips would be appreaciated. I plan to go in early this year and try lots of practice before the other boats go in.
Thanks,
-Scott
Thanks,
-Scott
