WMW Marine Authorized Grady White OEM SupplierTaylor Marine Centers - Milford, DE & Ocean City, MD
Fuse panel upgrade
General questions and answers about Grady Whites
Moderators: Seafarer228G, Potterbuilt
Fuse panel upgrade
Postby amr72 » Jul Thu 09, 2009 11:48 pm
I have a fuse panel for my dash mounted under my helm. It holds those glass fuses and I would like to upgrade it. West Marine has a Blue Seas one for $89. Has anyone made this change and can recommend the best options. I have my electronics wired to this fuse panel via the acc switch and I suspect it may be a weak link in the system...
1993 255 Sailfish
2003 200 Mercury Optimaxes
amr72
Postby richie rich » Jul Fri 10, 2009 1:21 am
There are several makers of these panels...Blue Sea, BEP, Paneltronics etc...Blue Sea is good, but West Marine is probably the most expensive....try online somewhere as you look for the same model since you like it.
Most panels have main power wiring coming into the panel to power the whole thing, and then you will have the individual wires from each accessory that will be attached to the appropriate toggles....I would cut and make new end connections for all your wires to be sure they are solid....use shrink tubing over the connector and put a light coat of electical connector grease (sold in small tubes in most marine stores) on the final connection to keep salty moisture out.....all units should come with an installation guide and use your owners manual to trace or color code your wires.....you may need to modify your existing hole to make a new panel fit.....lets see your handy work!
richie rich
Blue Sea
Postby markb8608 » Jul Sun 12, 2009 2:52 am
Hi
I purchased a (8 or 12) Blue Sea at West Marine for $54. I took a marine outboard repair course at a local vo-tech. The prfessors said the Blue Sea in "tinned" and is the best panel.
I plan on taking a picture before I remove old fuse panel. I think you can get enough room to simply disconnect mouting screw but leave fuses and wires attached to old panel.I plan on mouting new panel behind the (temporarily hanging ) old panel so I don't get mixed up when re-attaching the wires to the new panel.
Mark
markb8608
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 11 guests
Anglers Edge Marine
