Sea TowNeed a boat cover or bimini top? Contact Boat Covers Direct.
Scupper Hose Replacement
General questions and answers about Grady Whites
Moderators: Seafarer228G, Potterbuilt
Postby '84Offshore » Feb Sun 21, 2010 2:51 am
the hoses that go from my deck drains to the scuppers are dried out and need replacement. The hoses are VERY rigid......any hints on replacing them? Do the scuppers need to be removed?
'84 241 Offshore
'84Offshore
Postby no problem » Feb Sun 21, 2010 3:53 am
I just replaced my scuppers about an hour ago. If you still have plastic scuppers it would be a good time to to consider stainless steel. I just installed gemlux scuppers from ebay @ $40 each. If I were going to change the hose only I would cut them in the middle with a sawzall with a metal cutting blade and remove them in 2 pieces. Hope this helps. Jim
1992 dolphin 253GT
twin 200hp suzuki 4 strokes
no problem
Postby cdwood » Feb Sun 21, 2010 12:21 pm
Can't tell from your sig pic but if you still have any of the plastic thru hulls still in place you are definately pushing your luck and that includes your transon scuppers.
Mine grenaded last season, luckily I noticed them right away.
Pretty sure I saw an article last seaon with a pic of a guy sitting on top of his overturned hull waiting to be picked up by the CG.
Article stated he was taking on water because of a failed thru hull fitting.
For your peace of mind if nothing else since you may or may not get any warning before they fail and they will fail.
time on the water is time well spent. 85 204c w/a
the "Essence".
cdwood
Postby ahill » Feb Sun 21, 2010 1:16 pm
Has any one accesed 272 starboard scuppers without cutting in some access plates?
I've heard the heater hose used referred to as 10 year hose because thats how long it lasts.
ahill
Postby '84Offshore » Feb Sun 21, 2010 1:53 pm
I plan on removing the hoses today and will look at the scuppers....I think they are plastic. the port side thru hulls are bronze (?) but the starboard sides are plastic........guess the PO only replaced 1 side......
'84 241 Offshore
'84Offshore
Postby '84Offshore » Feb Sun 21, 2010 6:23 pm
Removed hoses today......scuppers seemed fine......gave them a few good tugs when removing the hoses and all seems well.
The deck drains were also removed when the hoses were removed......don't like the way they are going back in.......seems like they a "cocking" when I tighten the flange under the deck.......haven't put them in permanently yet.......maybe it just needs silicon?
'84 241 Offshore
'84Offshore
Finesse!
Postby JUMPNJACK » Feb Sun 21, 2010 11:05 pm
84Offshore! Good to see you pop up! Right after you started this post I did a check on my thru hull scuppers. They seem heavy duty and in good shape. I figure with your mechanical finesse that those pesky deck drains don't stand a chance. They will lay back down correctly! I think that leaving the hose clamps loose on the scupper end until you get the drains down flush might help? You might have noticed there was another little I/O thread a few days ago that could probably use your valued input! 8)
Ken
1987 254 Sailfish "JUMP N JACK"
'06 Mercruiser 350 MPI Horizon
JUMPNJACK
Postby '84Offshore » Feb Mon 22, 2010 12:46 am
Hi Ken.......
I installed the port side hose and r-installed the deck drain.
Finished product was fine........next week I will do the starboard side.
Think I did see the other I/O thread......will look at it again though!!
'84 241 Offshore
'84Offshore
Postby bdevlin5983 » Feb Tue 23, 2010 4:32 pm
'84Offshore wrote:Hi Ken.......
Where did you get the new hoses, if you8 don't mind my asking....?
Bren
1986 Grady 204C Overnighter w/ 2007 225 E-Tec "Somewhere"
bdevlin5983
West Marine
Postby '84Offshore » Feb Tue 23, 2010 5:03 pm
I bought the hose at West Marine.....I bought the white hose.....it's more flexible than what was in there.
'84 241 Offshore
'84Offshore
Postby bdevlin5983 » Feb Tue 23, 2010 5:54 pm
Thanks!
bdevlin5983
Postby RUMBLEFISH » Feb Wed 24, 2010 1:19 am
I think you should really use the black wired exhaust house for your scuppers just like they came from the factory. Yea I know they are a real bear to work with you may want to look into this. Then again I may be wrong but thought I read something about this in the past.
BLEED THE BLUE AND BOW TO THE COW!
89 25 Trophy Pro 2006 twin 200hp hpdi yamahas
RUMBLEFISH
Postby bdevlin5983 » Feb Wed 24, 2010 2:14 pm
Does anyone happen to know what size exhaust tubing it is? Not that I am lazy, but the boat is 2 hours away under shrinkwrap... Hoping to get all of these parts together before the unwrapping / "summerizing" weekend at the end of March.
Bren
bdevlin5983
Postby Grog » Feb Wed 24, 2010 3:38 pm
For those that are a real bear to reach, there is a silicone version that will last longer. If you're changing the hose and you have plastic scuppers, do them too.
Grog
Postby '84Offshore » Feb Wed 24, 2010 4:37 pm
The hose I bought was 1 1/5".
'84 241 Offshore
'84Offshore
Next
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 4 guests
Sea Tow
