WMW Marine Authorized Grady White OEM SupplierTaylor Marine Centers - Milford, DE & Ocean City, MD
First time bottom paint question
General questions and answers about Grady Whites
Moderators: Seafarer228G, Potterbuilt
Postby john90290 » Feb Thu 14, 2013 4:38 am
I have a 1996 adventure that's lived it entire life on a trailer and I've got it sitting in Southern California waters now year round.
I plan this and would like some feedback.
Power wash
Dewax
Sand
Petit epoxy primer for barrier coat x3
Pettit Trinidad SR x2
I've read many people don't use barrier coats, what do u guys think? I got a quote from a yard and told them that I had a fiberglass boat that had never been bottom painted and he quoted me 1400 for prep and two coats of bottom paint, no barrier?
Also, given the dry times per pettit of at least 6 hours per coat in 50 degree weather, how many days will this take? I can't imagine the boat yards down here put on one coat and call it a day? I've heard people say to wait for the barrier coat to tac off for a couple hours them hit with another coat as the coats will chemically bond?
Also, per Pettit, at 50 degrees I have to wait 120 hrs until launch after final coat?
Are these just guidelines that the company recommends but the industry disregards?
I want to do it right the first time so any guidance would be super helpful. I had an older boat that I would jut bottom paint but this Grady is so nice I want to do it justice
john90290
Re: First time bottom paint question
Postby NOTHING ELSE MATTERS » Feb Thu 14, 2013 4:55 am
Epoxy barrier coat is a must, especially if the boats lives in warm waters. Three coats is the way to go, then two coats of hard bottom paint(let's say blue color) then one or two coats of ablative bottom paint(let's say black color). When you see blue color you should touch up that spot with black color.
GIORGOS
TAKE A KID FISHING
2008 GW336 W/T F350'S [b] FOR SALE[/b]
1974 GW 191 SPORTSMAN W/JOHNSON 140
1981 FORMULA F-233 UNDER FULL RESTORATION
FISH ON
TAKE A KID FISHING
Postby ocnslr » Feb Thu 14, 2013 4:21 pm
NOTHING ELSE MATTERS wrote:Epoxy barrier coat is a must, especially if the boats lives in warm waters. Three coats is the way to go, then two coats of hard bottom paint(let's say blue color) then one or two coats of ablative bottom paint(let's say black color). When you see blue color you should touch up that spot with black color.
Concur completely.
Please note that the timing of recoats of the barrier are critical for proper bonding. Same with the timing of the first paint coat after the last barrier coat.
If they don't get it right, it will likely come off in the future, in large sections.
I know from experience, and the yard had to completely re-prep the bottom and redo the barrier and all paint coats.
Brian
2002 Islander 270 - 2006 Yamaha F150s
Tidewater Grady-White Club
ocnslr
Postby ahill » Feb Thu 14, 2013 10:10 pm
Make sure you allow 1inch + above the noted waterline for paint to accommodate different loads.
Don't forget your motor parts that will be submerged.
Usually lower part of mount, trim apparatus and nose cone of gear box.
Treat with pettit metal primer, Q-tie ( follow directions) and top off with bottom paint.
Also add zincs to your tabs & keep an eye on the motor & tab zincs.
Stray current from adjacent boats or marina electric distribution can also cause problems.
ahill
Postby john90290 » Feb Thu 14, 2013 10:24 pm
All great advice guy!! Thanks.
Looks like this will take at least 4-5 days. This is the chart for the petit primer and bottom paint.
Day 1: Prep
Power wash, dewax and sand.
Day 2.
1st coat primer wait 6 hours
2nd coat of primer, 1
Day 3
3rd coat of primer, wait 6 hours
1st coat of bottom
Day 4
2nd coat of primer
Day 5
Lauch after 24
Primer:
Substrate Temp : 50°F
To Recoat: 6hrs-14 days
To Bottom Paint: 7-10 hrs
Bottom Paint:
Temp 40°F
To Recoat: 12hrs
To Launch: 24hrs
john90290
Postby ahill » Feb Fri 15, 2013 2:35 pm
The time between coats of metal primer & q-tie is short and critical.
Check directions before starting that phase.
ahill
Postby onoahimahi » Feb Sat 16, 2013 2:15 am
Guys - is the barrier coat really necessary? Do we not trust the gel coat? The 94 Sailfish I just acquired was lift stored and needs it's first coat of bottom paint as well.
Sailfish 27
E-Tec 200HOs
onoahimahi
Images: 2
Postby ahill » Feb Sat 16, 2013 2:45 pm
Absolutely, dewax well first.
My 272 went from trailer to water.
The yard dewaxed then applied 3 coats of epoxy barrier coat before proceeding.
ahill
Postby seasick » Feb Sat 16, 2013 3:07 pm
ahill wrote:Absolutely, dewax well first.
For me, the question depends on the use and age of the hull. If I bought a new boat and had to paint the hull with anti-fouling, I would probably barrier coat.
On the other hand, if I bought a several year old hull that had been used AND close inspection of the hull showed no blister issues, I would be less inclined to go forward with the expense and effort to 'correctly' apply barrier coat. This is especially true if the hull had been previously bottom painted since insuring a good base for barrier coat is a bigger challenge.
There are cases where blisters wax and wane as moisture enters and exits the laminates. Barrier coating such spots can create more issues when existing moisture can't get out. Note that epoxy barrier paint can slow the development of osmosis blisters but it won't fix them. Boats that are left in the water year round are better candidates for barrier coats since any hull given enough time in the water will absorb some moisture. Boats that are seasonally stored in the open or in a storage facility will 'dry' out during that storage.
Gel coat as mentioned is a pretty good moisture barrier. If you sand away the gel coat or damage it, a barrier coat can help. I guess what I am saying is that for me there is no definite yes or no for barrier coating.
My personal experience with barrier coating ( Inter-protect 2000) is that even with meticulous prep, some chipping of the paint will occur over time. I am not sure why but each season I have some chipped areas to spot repair.
Postby Shutterbug » Feb Sun 17, 2013 1:22 am
I don't understand why it's necessary to apply hard bottom paint over a barrier coat in between the ablative. I don't know what color Pettit's is, Interlux was or is grey. When the black ablative wears off the grey barrier shows through on mine. Money saved on the hard.
Shutterbug
Postby seasick » Feb Sun 17, 2013 12:24 pm
Shutterbug wrote:I don't understand why it's necessary to apply hard bottom paint over a barrier coat in between the ablative. I don't know what color Pettit's is, Interlux was or is grey. When the black ablative wears off the grey barrier shows through on mine. Money saved on the hard.
I agree.
Postby NOTHING ELSE MATTERS » Feb Mon 18, 2013 5:49 am
When you sand the ablative paint to apply the new one, if you don't have the hard under it you will be sanding the barrier coat, besides gives the extra protection and you only do it once(the hard).
GIORGOS
TAKE A KID FISHING
FISH ON
TAKE A KID FISHING
Postby seasick » Feb Mon 18, 2013 1:29 pm
You don't need to sand that agreesively. Just a light sanding or no sanding at all for many ablatives. I use a scotchbrite pad. If you sand hard enough, you can sand through hard also.
The hard will add drag and weight too and that can affect performance. I just don't see a need for a hard coat under ablative.
Postby john90290 » Feb Thu 21, 2013 5:42 pm
Emailed Pettit about dry times. See response ( and my question ) below. Thought this might help others.
Thank you for the e-mail. As long as the paint does not come off on your
finger then you can recoat. Use that as your guide, as dry time are
effected by different elements
Check out the new www.pettitpaint.com !
Joe Petrocelli
Customer Service
Pettit Paint
Ph 973-776-8274
Fax 973-625-8303
To: <jpetrocelli@kop-coat.com>
Date: 02/21/2013 10:59 AM
Subject: Ask The Expert Question
Submit Date..: 2/21/2013 10:59:03 AM
Question.....: Bottom painting 22 foot fiberglass boat. Read all
instructions. Doing the Dewax and barrier coats then Trinidad sr. Read all
the data sheets. Temps will be low of 50 high of almost 70. Want is the
minimum drying time for epoxy , Pettit 4700, between coats. Data sheet
says 6 hours but I've read to use you thumb to test the paint. If it leaves
a fingerprint and does not take up paint, it's ready for recoat?
Looking for real world advice or should I stick to the book.
john90290
Postby john90290 » Mar Fri 01, 2013 5:56 pm
Well, after all of the fact checking, research and advice from you kind folks, this weekend it begins...
Picked a nice weekend as well, a little heat wave on the way, temps in the 70's and 80's for the next two days!
Will take pics and update.
john90290
Next
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 12 guests
Carolina Boat Brokerage
