So I started this project last night, I cant recommend enough to check these things on a regular basis and to change them if your still dealing with the plastic thru hulls. I started with the hard to reach ones under the helm. Just loosened the hose clamp enough to pull the hose off, one little tug and the fitting broke. Then the 7 others were the same way. I was like wow, at any time this thing could have snapped and I would have a ton of water flowing in. So guys give these a check there kinda critical, they looked for the most part fine no cracks etc, but it was way worse then I had thought. The new ones are going in this weekend.
