Hi - I've been unable to make sense of the claims of various owners and manufactures and decided to do some of my own research and analysis. I went to the manufacturers web sites and downloaded data from similar size/weight center-console boats so I could examine them together on the same plot. They are mostly 25-foot boats with dry weights of about 3500 lbs. Since the hulls are not identical, the absolute values may not be representative; however, the relative shapes and locations of the peaks  are interesting.
The first plot shows three 2-strokes and an F250. The F250 has the highest MPG at 3000 RPM but over a fairy narrow range. All the 2-stokes peak closer to 4000 RPM at which two out of three show higher MPG then the four-stroke. At WOT, they all converge to the same value.
The second plot shows MPG vs speed for the E-TEC and the F250. The F250's sweet spot is at 24 MPH. The E-TEC has a broader sweet-spot from 27-32 MPH. There is a cross-over point at 30 MPH above which the 2-stoke is using less fuel.
The most astonishing difference between the E-TEC and the Yamaha F250, however, is the low-speed performance. The E-TEC slow-speed trolling performance is an incredible 11 MPG. I probably wouldn't believe that if I wasn't getting 8.3 MPH tolling with my Sailfish on a single engine and 6.7 MPG when using both engines. Since most outboards spend most of their lives running at 1500 RPM or less, this is an important consideration.
The boats:
http://www.evinrude.com/Content/Pdf/neu ... /PE871.pdf
http://www.yamahaoutboards.com/sites/de ... 13_OCC.pdf
http://www.mercurymarine.com/engines/en ... 9106724709
http://www.yamahaoutboards.com/sites/de ... 00txrc.pdf
Cheers,
-Scott
The boats:
Cheers,
-Scott
