- Jan 31, 2005
Hi
I wanted to change out the white plastic cup holders with the newer stainless steel design. I thought I'd share as it wasn't easy to locate them.
GW gave me the part number 10-1087 The SS with the drain hole at the bottom is about 3.25" deep. They are manufactured by Research Design Innovations in CT. They come with a cap for the bottom for non drain locations. The website is www.rdillc.com. They sell some with LEDs around them and some other unique things too.
FP Marine (appears to be Sea Ray Parts distributor) sells them on the net for $7.50 each. Www.fpmarine.com. So for my cockpit transom cup holders I plan to connect the drain hoses and install. For the 2 helm and the 2 cabin locations, I will use the drain caps on the bottom so no water leaks out.
Pretty inexpensive upgrade FWIW.
