LED Flood Lights
These look pretty good for the money if you want brighter spreader lights or want to add one to your hardtop. I'm going to replace mine. 1/4 of the current draw and brighter. I beleive he has pencil beams as well in this form factor.
He sells an led stick for under gunnel mount or inside fishboxes, below deck etc that look pretty robust too.
No affiliation, just passing it along.
http://www.thehulltruth.com/parts-forum ... -99-a.html
What, no one has LED flood lights? What's Grady doing and what do you guys use, still using the 55 watt Hobbs?
I' m not happy with my LED floods as both had to be replaced, very little use and sections of the array panel had died.
I just picked up a Lumitec Caprera 2. A little more coin, but looks mint. Dual color white/Red too. I really like the idea of the red light option.
Boss Tog was it easy to switch the LED lights with the ones that were there? Did you have to add a low voltage box or anything?
