- Mar 24, 2009
- Indian River, DE & Chesapeake Bay
I am attempting to replace the through hulls as they appear to all be original. I am mostly concerned about those below the waterline. Am having trouble with what I believe is the deck and fishbox drain on the starboard side. I am accessing them though a wood panel in the stern of the head (giving access under the deck below the helm) then through a round access panel to the hull. Problem is the access hole is well forward of the through hull fittings and I can't get my hands in to remove the hose or the lock nut. Add to it the hydraulic pump for the trim tabs is in the way. Is there another way to access these fittings? Thanks
