Boe Marine, Marine ElectronicsSea Tow
Gas Tanks - help
General questions and answers about Grady Whites
Moderators: Seafarer228G, Potterbuilt
Gas Tanks - help
Postby georgemjr » Apr Thu 02, 2009 12:14 am
Any information on gas tank suppliers/price. Has anyone replaced them? 1987 24 Offshore with a gas leak, expecting the worst. Thanks
'00 30 Marlin
georgemjr
Postby sfc2113 » Apr Thu 02, 2009 3:32 pm
I hear good things about this company, am going to get mine from them next year.
http://www.patriotmarinefab.net/1650552.html
Paul
1986 204C Overnighter
1998 175 Evinrude Ocean Pro
"Lady Sandy"
sfc2113
Postby cdwood » Apr Thu 02, 2009 8:11 pm
Atlantic Coastal Welding in Bayville NJ did mine. Good work, good price. They are just outside of Tom's River.
time on the water is time well spent. 85 204c w/a
the "Essence".
cdwood
Postby Legend » Apr Thu 02, 2009 8:12 pm
Mosy of the GW dealers have good local fabricators that they deal with in replacing tanks
2004 Sailfish
2017 F250 Twin Yamahas
Legend
Postby Sinclair » Apr Thu 02, 2009 9:37 pm
I used Patriot Marine last year when replacing my tanks on my Sailfish. Replaced both tanks. The service was top notch. I went up to pick them up, the guys gave me a tour of the plant and showed me in detail how the tanks were made.
Great Experience.
Sinclair :D
On Course Custom Charters
www.oncoursecustomcharters.com
Sinclair
Postby wilson » Apr Sat 04, 2009 12:36 am
acw in nj. i took out my tanks and replaced with one big one. awesome job. they worked with me. no more threeways or switching, just one big tank now.
wilson
Postby Offshore24 » Apr Tue 28, 2009 4:09 pm
I bought mine from the guys in FL that made the original tank. I paid shipping and got a tank that fit the first time around.
I figured doing the install myself covered the shipping.
1987 Offshore 242
F225 Yamaha
Casco Bay, Maine
Offshore24
Images: 1
Postby BobP » Apr Tue 28, 2009 5:23 pm
Other guys with older Gradys, you can save the tank before it leaks, but have to pull it to inspect it and stop the pitting corrosion if going on, no need to wait until it leaks.
The tank will last forever if not for tiny perforations from corrosion, typicaly.
DIY stopping the corrosion is easy, hardest part is labor getting it out and back in, also can do fuel vent /fill/feed lines then, and clean the internals, and new level sensor.
Although not so good a time now, end of season is better.
And it' s not a pay me now or pay ne later deal, it's more like pay itty bitty now, avoid paying hand over fist later, at the most desperate time when it occurs - per Murphy's Law.
1979 20 ft Mako
1988 Overnighter 204C
1992 Sailfish 252G 2006 200 HPDIs presently
BobP
Postby Offshore24 » Apr Wed 29, 2009 12:03 am
How do you stop the corrosion or fix the damage? My tank wasn't leaking but i will bet you there wasn't a 1/32-in of metal left in some of those pits on the botto of my tank.
1987 Offshore 242
F225 Yamaha
Casco Bay, Maine
Offshore24
Images: 1
Postby BobP » Apr Wed 29, 2009 6:31 pm
It is not advised to try to fix a hole in a gas tank when it is has already perforated, unless you can get someone to weld and they know how to run a continuous purge of Nitrogen while welding, otherwise stand on the opposite side of the marina when they are working, and wear a hardhat.
Many times, NOT ALWAYS, the corrosion is galvanic type, and limited to pits, in an area isolated to under a few of the neoprene strips. There is a reason for this. The pits on my tank were about an 1/8 inch diameter, a few a bit more, perhaps the biggest 3/16in.
If the corrosion is broad based and thinning large areas of continuous metal, that's different, BELOW DOESN'T APPLY:
The tank is 1/8 in. alum, not much to begin with but a lot more than you will believe in strength for the application.
But a fine pit does not weaken the tank since the area is tiny vs a square inch. even if the pits are numerous but well spread out, so, all the tank has to be capable of is passing a pressure test, I think the design is 4 psig (lbs per square inch), it will be on the tank's nameplate, verify it.
Fine well spread out pits will pass any pressure test, assuming the pit is less than say no more than 50% of the depth , you can eyeball this after cleaning the area.
So you clean the area, I use a cone shaped dremel stone (LIGHT TOUCH ON SLOW SPEED NOT TO MAKE HEAT NOR PENETRATE THE TANK AND GO KABOOM) to get the pits cleaned out as a prep for primer.
Sandpaper the rest of the.
As an option, you fill pits with marinetex flush, and smooth and apply alum primer. Let it dry, now renew surface of neoprene strips by running a belt sander over them both sides while stepping on one end on a piece of scrap wood, makes them nice and grippy - takes the shine off, clean with denatured alcohol and bond to the tank with LIFESEAL, full face seal.
Then when you are done, take a vacation on what you saved, and have a beer on me.
If you keep the boat 3-5 more years, pull the tank and do same inspection to verify condition, do the same every 3 - 5 yrs, tank will last as long as the 30 + yr old jet you flew out on vacation!
Same aluminum both are made of !
And your boat motor wil run theh same, old tank / new tank.
Be carefull working around gas and gas tanks, if you don't know what you are doing, don't mess with it, contract out.
Good luck.
1979 20 ft Mako
BobP
Postby Yamama » Apr Thu 30, 2009 7:57 pm
I used ACW also. Excellent work and delivered here in Maine in less than a week from time of order.http://www.speedytanks.com/
Yamama
Postby NOTHING ELSE MATTERS » May Fri 01, 2009 1:31 am
I used twice RAM Welding Inc in Farmingdale. They advertise in the Fisherman magazine too.
GIORGOS
TAKE A KID FISHING
2008 GW336 W/T F350'S [b] FOR SALE[/b]
1974 GW 191 SPORTSMAN W/JOHNSON 140
1981 FORMULA F-233 UNDER FULL RESTORATION
FISH ON
TAKE A KID FISHING
Postby Parthery » May Fri 01, 2009 11:52 am
Both Florida Marine Tank and RDS made aluminum tanks for GW at one time.
I used RDS to replace the tank on a 19 Tournament that I owned. They had the plans and were able to custom build me the exact replacement in less than a week's time, then deliver it to my door via UPS.
Their phone number is: 850-584-6898
2000 GW 225 Tournament / 225 OX66
Parthery
Tank life
Postby OrionNC » Nov Sat 21, 2009 9:31 pm
Is there an average life for Grady tanks? What is the best way to test the condition of a tank? How often should it be done?
OrionNC
Replacement Gas Tank for 1991 228G Seafarer
Postby Scott W. » Feb Tue 02, 2010 7:49 pm
Just replaced my 19 year old original Grady-White 93 gallon gas tank with one that was manufactured by Phil at Alloy Metal Works in Farmingdale, NY (631)694-8163 alloymetalworks.com. I found out that most of the marinas on Long Island use Phil for all their gas tank needs and then mark up the same to their customers. First I siphoned out most of the gas, then I removed my tank by placing two rachet straps under the tank and then racheted up the tank to the deck. The tank doesn't weigh too much when it is empty (about 60 lbs). I cleaned up my bottom rusted tank (not leaking yet) and dropped it off at Alloy Metal Works; they also disposed of my tank at no extra charge. They charged me about 1/2 the amount that the original manufacture (located in Florida) wanted for the same; I paid about $750 with a WEMA fuel sender. Before I installed the tank, I applied Zinc Chromate Primer to the tank then glued neoprene strips with 5200 to the bottom of the tank where the hull supports meet the tank. I also replaced all the fuel lines. By doing this job by myself, I saved approximately $1,000 in labor costs.
Scott W.
Next
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 6 guests
Anglers Edge Marine
