192 tournament walk thru windshield hinge broken
Majorstu
Tournament 192
Hello, is there a dealer and/or shop on the west coast that can repair/replace the windshield problem noted in the subject line? I'm in the Seattle area - thanks
Parthery
Atlanta, GA
Do the clips that hold the windshield to the hinge look like this? If so, they are part number 09910 from Taylor Made Systems. I just ordered 2 replacements for my walk through windshield today. Their customer service / order email is tms@taylormadesystems.com
Majorstu
Tournament 192
NO; there’s no plastic clips, only the hinge pin and foam strip - see attached pic. Thanks for the info RE Taylor made systems!
Parthery
Atlanta, GA
They probably have yours as well. Send them an email and pic.
ScottyCee
Samish Island, WA
Did you call Jacobsen’s Marine? They’re not too far away and they’re a Grady dealership.
HBerge
Tournament 192
I need the same hinge pin on a 192 and am located in Olympia. What did you find?
dfolsom123
Tournament 192
i know this is an older thread, but I had the same problem. The aluminum pin broke on my windshield. After I removed the old pin, I bought a really long thin drill bit to clean out the hole. Then I bought a length of aluminum round stock and replaced the prior pins. It was a bit of work, but fixed the problem.
Cabe123
Tournament 192
How did you remove hinge pin
dfolsom123
Tournament 192
we bought a super long skinny drill bit at home depot and carefully drilled the old one out. Since it is aluminum, it was not that hard to drill out
