1989 Grady white overnighter cabin walls rebuild
miketoohotty
I have a 1989 overnighter that I'm trying to rebuild captains side cabin wall and side by electrical if anybody has some pictures of walls apart and dimensions would be appreciated
Hatteras204-C
I am restoring a 78 Overnighter. I will send you a picture of my captain's side cabin wall. saved it to use a template.
miketoohotty
K thank bud yeah the guy before me made one out of starboard I think might be close but don't trust it
Hatteras204-C
I will get you the pictures tomorrow. Totally, understand wanting to make it solid. My wall has zero glass on it. I plan on remaking it out of marine board and glassing it properly.
miketoohotty
Yeah I'm using 3/4 ply and using sealer and stain and it's going to be blue on white boat think it will look awesome
Hatteras204-C
Great template material... go to HD or Lowes and get a sheet or two of the pink/purple foamboard insulation. It's cheap and easy to cut/sand. When you have your template just right, then cut the final product out of your chosen material. You can tab the foamboard together with glass/epoxy, too.
Reactions: Hatteras204-C
miketoohotty
Does anyone have measurements of inside wall on captains side where wires go down into floor trying to make one up with no old peiece and it is a pain thanks
See post #12 :)
As smart as the guys on here are, this is something you want to do yourself and not trust someone else's measurements
