I attempted to remove my '95 268 Islander 134 gallon tank by cutting the bulkhead directly behind the tank. With said bulkhead removed, the tank would not come out due the length of the tank in relation to the steps. I toyed with the idea of cutting the bulkhead forward of the batteries to see if that would provide enough room to slide it out. It didn't look like (to me) that would provide enough additional room to slide the tank out due to the stairs. I didn't cut that bulkhead to try it. I tried to research, short of calling Grady, but could not find any detailed info. This was a few years ago. I wound up using a borescope to inspect the tank the best I could and set it back in place. Hopefully someone has experience with this I would be very interested in your progress. Historical discussion with a little more detail regarding my removal attempt in link below.
-Dan
Has anyone successfully removed the main tank from their Islander? I understand I have to cut the bulkhead and slide it back but wondering if there is room to actually get it out inspect and hopefully reinstall. I am currently re-coring the soft deck and wondering if I should tackle the fuel...
www.greatgrady.com
