I could not use the boat for 3 weeks, and when I tried to start the boat yesterday I had a lot of trouble! Is this a common occurence after letting the fuel sit for as little as 3 weeks?? I do treat the fuel with a stabilizer at each fill up. I had about 35 gallons in the tank(which holds 80 gallons). Could it be water, or separation of the fuel resulting in burning alcohol?
Another symptom was a lot of smoking after it finally did start. It would start and quickly shut down several times, then not start at all for quite a while.
BTW engine is 1997 175 hp Johnson Ocean Runner with about 350 hours., new power pack and new optical sensor this summer. Engine ran great 3 weeks ago, and ran great yesterday after the initial battle to get it started.
Thanks for any suggestions!
Rod
1985 Fisherman 204
Rod
1985 Fisherman 204
