- May 13, 2018
Have a Tournament 225 with the outboard on the factory bracket. Looking to install the Lowrance active scan 3in1 transom mount transducer. Is there anything different when installing a transom mount transucer with the outboard being set back on the bracket? Most sites say at least 15" from side of prop with an outboard hanging directly on hull. Boat trailer bunk and trim tabs are also getting in the way. I can get 15" from center of hull but any more will be an issue. Thanks for the help!
