2018 Express 330 - thru hull fittings
Chatham330X
Curious to know if anyone else has lost the external fittings on the starboard side thru-hull discharge outlets? Trying to find the specific part numbers and/or diagram for the thru-hull fittings. Thanks!
Chessie246G
Maryland
What does "lost" mean? If factory fittings got eaten up this quickly, and the boat is slipped, I would be checking for excessive current leakage around the dock.
Agreed! Hell, my 92 were still there and working correctly when I bought the boat last year. They have since been changed. Def should have a service life of more than 5 years.
Chatham330X
Port side. Not sure if it is missing external fitting or this is just a different type of thru-hull. The exact same boat next to me has all matching thru-hull fittings.47B3E14B-E34C-434B-9F4E-ED7F0D81EFCA.jpeg
wspitler
Inglis, FL
Doesn’t look original GW to me? First you said starboard then port? What does it drain ? Owners manual will ID all thru hulls. Gunnel fitting also looks nonstandard.
Chessie246G
Maryland
Stainless thru hulls are all one piece of stainless. Im guessing someone swapped that one out at some point
Below the water line thrus should not be stainless. More appropriate would be chromed bronze
