3" hook latch for transom door 33 grady
mfl1375
Our hook latch is bent and wont fit to keep the door open anymore. Does anyone know where to find the hook latch for the transom door on a 33 grady. It is a 3" hook. Thanks!
Can contact GW through the cust service link on the website and get the details. They may even have it in stock at your local dealer.
Looks like it may be 10-270. Check with GW. They should be able to match it up.
mfl1375
I know. I think it got caught in the door, which doesnt make sense. Also it is secured by a bolt and not a screw. Nothing is easy, but love our grady and built so well.
kirk a
Massachusetts
Pretty sure the replacement for mine actually was found at west marine.
Lucky13
mine is bent also let me know how you make out finding the part
mfl1375
Utter failure so far. Will let u know if i succeed. And if u fo please let me know.
Stephnic
Somers Point NJ
A friend just orders his from Taylor Marine in Delaware. They will ship them right to you.
GW should be able to provide info on that. It hasn't changed in years. They should have a GW part number that you can order from a dealer or they may provide the actual source and you can go directly to them. Give GW a shout and see if customer service can help.
mfl1375
We got the part. or at least ordered it. It was only $40 for the side. I say only because I did expect worse. But it is specific and couldnt find anything in the after market that had the same screw hole spacing. If anyone wants the part #, let me know
Glad to hear it worked out for you.
