- Jan 31, 2005
Hi,
Wondering if anyone had a starting issue with their generator and could share some tips.
When the power button is pressed and all leds illuminate as they should. The start button is depressed and the generator usually starts right up.
The last few times, I hear a repetitive clicking noise, almost sounds like a relay engaging and disengaging when the start button is depressed. If I hold for too long the 25A fuse on the generator poped - only did this one time. If I depress the start button 2-3 times for 5 sec each time, the generator usually catches and starts.
I tried the K1 relay as suggested by FP as this is a pretty cheap part. The solenoid and starter are one unit sold together. I plan to pull the starter/solenoid and see if anything is sticking or keeping the starter motor gear from engaging and maybe lubing the spring/starter gear assembly and giving it a shot before buying a $350 part. Any advice or troubleshooting tips folks may have is appreciated.
