Fuel burn questions 265 and 268
Scott1115
If anyone can chime in and help me out that would be great. I am looking at a few 265's (Big boats) and 268's. Curious to know the fuel burn of each at cruise. I know the they may be powered by different displacement motors. Only interested int he 268's powered with twins.
Thank you
Fowl Hooked
Southern Maryland
On my 265 with the F225s and stock Yamaha props I was seeing about 1.7-1.8mpg at ~3800 rpm pushing me along at around 25-26 mph. This past spring I upgraded to new F250s as a result of the dreaded corrosion issues, I transferred the old props onto the new motors and at the same rpm/speed I'm now seeing about 2.0mpg.
drbatts
CT
Agreed. The 265 likes to run. I usually run mine at 27-29mph and mpg will drop to around ~1.5ish mpg.
wow, fuel economy improved more then I thought it would with the F250s.
Scott1115
DrBatts - what motors do you have? Im in Stamford; where are you?
drbatts
CT
scott,
I have f225's. Both engines have had the midsections done. They both had significant corrosion on the exhaust system when replaced. Otherwise they have been reliable engines. If you are looking at boats with these early f225's the corrosion is a well known issue, and replacement of the midsections is a pretty routine repair now. I would not be not be afraid of these engines, as long as the exhaust has been addressed. Boat is in Westport. If you have any questions feel free to ask. There are a couple of other local guys with 265s on here too.
Damian
drbattersby@yahoo.com
Scott1115
Thank you Damian. Well aware of the 225 issues. I'm on the hunt.
eppem
Trumbull, CT
I am a local 265 owner also - bought the 03 in 06 with 84 hours on it and they have well over 1,400 now. Regularly maintained, did 1,000 hour service and had the mids updated. Engines run like champs. I should be back in the water mid March if you want to check it out.
Fowl Hooked
Southern Maryland
The performance improvement all around with the 250s was pretty remarkable. The boat ran good with the 225s and if I'd caught the corrosion before it hit the powerbeads I'd have done the midsection work and kept on running, they had a bit over 1,100 hours but were going great.
The 250s though just run that boat better in all respects. I'm up on plane quicker, especially when fully loaded, and once there the boat just seems to cruise 'easier' if that makes sense. There is the noticeable difference in economy, though I don't typically see it as I generally run about as fast as the water conditions allow me to go, but it's nice to know what I can get out of them if I'm planning a really long run.
I also don't have to play with the throttles much anymore when pounding through chop - not the up and down for managing big waves but the cruising along in 2-3 and the bow digs in on a random wave. It's not like cruise control or anything but the engines sense the slowing in speed and rev up accordingly to get back to where I was and then slow back down to whatever they'd been set at before. My 225s didn't really seem to do that at all and I was constantly tapping the throttles.
Being forced to repower sucked but at least the cost for the upgrade came with some tangible performance benefits plus I no longer have to look at that unsightly scratch on the cowling. :)
captain swag
2001 265. 2011 Optimax 225s with 17 Rev 4s. 1.6 to 2.0 mpg at around 28 to 30 mph.
