Gelcoat
grady daze
Clearwater, FL
:?: I'm purchasing a 1987 GW 258 Trophy Pro, one concern of mine is that the gelcoat in some areas of the hull have rubed away so that you see the actual fiberglass. Should this be a concern :?: [/b]
Grog
Yes!
You don't want water getting in the fibers.
oldmil007
shapleigh maine
If you can post a picture or two of the affected hull areas you'll get plenty of good advise here re: the repair process.
- Jay
striped bass
Watch Hill, R.I.
You might be asking for major work. Also this may be an indication of other maintenance headaches elsewhere that you can't see. Go with a more recent model of you can.
