Grady 228 switches
EZ turner
when I sit behind the wheel on the Grady 228 and move around my right hip hits the switches and they go on without knowing what I did , any solutions or I am missing something.
What switches are you referring to? The steering wheel protrudes the furthest, so I can't imagine how you would hit the dash before hitting the wheel? Do you have a pic?
Dennis, I understand what he's saying. Somewhere around '05-'06 Grady changed the switch location. My '04 is next to my right hip/leg while facing forward, the other pic is the '06 and it's further forward by right knee facing forward. Less of a chance to turn the switches on by accident.
Reactions: EZ turner
Ah, OK. Now I understand. I just couldn't imagine how switches on the dash, forward of the steering wheel (in the 'normal' place), where getting bumped. Thanks for the pic - that clears it up.
Gonna have to think 'bout it for bit... modding that plastic cubby to make switches flush, instead of angled... replacing with an older style cubby and relocating switches...
Someone had posted a pic of their switches and it had a bar running across them, it would help some, but you could still bump the switches on. I looked back through old posts but couldn't find the pic.
I guess the other thing is that the boat might be new to you, EZ? In time, you'll get used to it and it will become second nature to check the switches.
You could make that bar big enough - or stick out far enough - to be effective, but then you'd be crashing into the bar all the time... eventually breaking it or the switch panel where it mounts.
Another solution would be to have a new panel made with flush, push-button switches. The buttons are, essentially, flush with the panel and you have to depress the center of the button with a finger.
EZ turner
Yes it is new to me the boat is 2004 , I am trying to figure things out, I took it out last Saturday for fishing, I installed Simrad electronics also so the 3 times I have been out my mind is all over the place, and the pumps going on on there own , I am sure somehow my hip is hitting them. I looked at the seat carefully last night it is not close to the switches maybe my leg is hitting them . So far I love this boat best boat I ever had.
EZ,,,,, trust me, you'll get use to it and it'll be second nature to check your switches. I have an '04 228 also and love my boat. I've done a bunch of work to it and been into almost everything on it, so if you ever have questions, feel free to ask. Post up some pics when you can, we all like to check out boat pics.
Here's mine.
EZ turner
For sure, I bought the boat in Tampa Bay had it shipped to San Jose CA , I have added Electronics Simrad which I am not too familiar with I always had Garmin, added a kicker motor, changed the corroded ball joint for the bilge pump not too fun but finally I did it. Thanks for the offer I will bug you guys.
Reactions: Ky Grady
EZ turner
I forgot, added weights to the new aluminum trailer it was floating.
Reactions: handinpalm
Mine came out of Tampa also, from a member on here. Lives in Kentucky now. Makes an occasional trip back to the saltwater every now and then, primarily a freshwater boat now.
wrxhoon
Sydney Australia
My old 228 had the switches on the side, the new one is forward like the second pic KY put up. I never had any problem with either but I'm only 5'8" and 75 kg ( sorry about 165 lb, I keep forgetting you guys are still none metric.
KY your boat will be one of the cleanest 15 yo 228's around .
Reactions: Ky Grady
Thanks hoon,,,I take pride in my ole girl. Labor of love and respect to bring her back to her glory. To own a Grady had been a dream of mine for years.
No, you're not. You could have just deleted the 75kg before you finished you're reply... but that's alright, a little sarcasm and humor is a good thing! :)
Reactions: wrxhoon
HMBJack
Half Moon Bay, CA.
When I had my 228 (which I regret selling BTW), I had the same problem.
What I did was make little wedges out of that black foam material you see restaurants put on the floor in their kitchens - the anti-fatigue type foam. Anything will do. The stuff I used was like 3/8" thick.
So I would take a razor knife or scissors and cut a bunch of these 1/2" X 1" or so foam squares. Then I wedged them into the switch so I couldn't accidentally turn on the switch if I bumped it. If I WANTED to turn on that switch, I simply pulled out the wedge. Simple and cheap. And I knew for sure the switches with the little wedges inserted in them were NOT on unless I wanted them on. Got it?
EZ turner
Very good solution , I bought a 3d printer several month ago I have made several parts, I will make a custom gard to go over the switches hopefully I will post pictures.
