Hey guys,
I have an engine problem that has been lurking for the past year that I was hoping someone else has (unfortunately) run into and could give me some advice on. The boat is an 01' 265 Express with 200 HPDI's.
Starting about mid-summer last year the port engine started to act up. I would be offshore trolling, pick up lines and be ready to come home, and the engine would not get over ~3500 rpm's. This was the first instance and we decided to just troll in, but after an hr or so, the engine decided it had full power again and cruised fine the rest of the way home. The problem didn't reappear until about three weeks later, only this time it was worse. It would not get up past 2500 or so and was fluctuating between 2000 and 2500 with a constant throttle setting. Problem disappeared again, and then reappeared another couple weeks later with symptoms once again getting worse. After this time it got so bad it would not even start after limping in on one engine.
Hoping that it was a bad filter, we replaced all filters in the engine and still had the same problem. It was hooked up to an aux tank and same problem so pretty sure it was not bad gas. After this point, it was beyond my knowledge so we took it to the marina at the end of the season and had them look at it. They diagnosed a bad high pressure fuel pump and replaced it and ran it twice and said it was fine. Well, I went to run it to our house for the season and after about 10 miles of running perfect, it would not get up over 3700. Again, it gradually got worse as I turned around to take it back to the marina, and by the time I returned, it would not make it over 2000.
Sorry for the long post, but I wanted to give as much info as possible. I'm stumped here and any info you guys could give would help A LOT.
Thanks,
Mark
Thanks,
Mark
