Yes, Suzukis have 5 mounting holes as opposed to everyone else having 4. Your best bet is to mount it in the 3rd hole down from the top, then measure your cavitation. Your anti-ventalation plate should be about 1/2" (12.5 mm) below the keel. Trim your engine down and put a straight edge along the keel. Run the straight edge next to the engine "foot" and measure the front part of the plate to the staight edge, then measure the aft part to the straight edge, and adjust the trim until the two dimensions are equal. 1/2" above or 1/2" below the keel, or in this set-up, the hull bottom, is just fine. That's what you should try to get. By the way, where are you from?
