- Oct 16, 2007
- Age
- 69
- Cape May, NJ
- Islander
I would assume that everyone knows that SeaTow discontinued automated radio checks. Apparently I was the last one to get the memo!
I purchased a new radio and antenna for my boat. I'm trying to test it to make sure its working alright. I setup the MMSI in the unit and used the Test Message function to the USCG All stations MMSI 003669999 to test the unit.
I got varied results. If I test it 5 times through the day I may get one ACK response and the rest are no response. This was the case over a 5 day period. I canceled after a minute - not sure if I would have gotten a delayed response.
I am located about 7 miles from Cape May, NJ slightly inland 20' above sea level on a trailer with antenna 13' above my driveway. I radio checked twice with SeaTow in Cape May loud and clear. Also DSC Loopback test has been 100%.
This morning I talked to Coast Guard Sector Delaware Bay today about my unreliable DSC Test Call ACK's. Couple of interesting things came out of it.
When you initiate an automated DSC Test Call it gets delivered to a single persons desktop at CG Sector Delaware Bay. I counted 8 towers that all funneled back to Sector HQ. Test calls are manually responded to and are pushed down in priority. Depending of volume coming in its not uncommon that you get a delayed response or none at all.
All recreational MMSI (BoatUS, SeaTow, etc) are not legal for International use and ARE NOT entered into the FCC National database. If you decide to move up to International use you must register with the FCC and a new MMSI will be issued. This is a PITA because its not easy to deprogram your MMSI and radio may need to go back to the factory.
The other thing is when an emergency DSC alert comes into a CG station the FCC National database is checked and both of my MMSI come back as unregistered. The operator has access to other databases (BoatUS, SeaTow, etc) and has to look you up there.
