- Jan 5, 2021
- South Coast MA
- Express 330
I am thinking about one for a new 228 to be used at the dock. I've seen several inexpensive ways to do it but as they say, cheap is cheap and not necessary goodThis is great. I am.looking for something while on the hook or docked. Thx!
Cheap is necessarily bad. If a good shade costs 10 times a cheap one but lasts 5 times as long, it may not be the better choice. The main issue is whether you need the shade to hold up when using the boat at sea and not just docked. If used only at the dock, the less expensive options might be fine.I am thinking about one for a new 228 to be used at the dock. I've seen several inexpensive ways to do it but as they say, cheap is cheap and not necessary good
AgreedCheap is necessarily bad. If a good shade costs 10 times a cheap one but lasts 5 times as long, it may not be the better choice. The main issue is whether you need the shade to hold up when using the boat at sea and not just docked. If used only at the dock, the less expensive options might be fine.
Two (maybe three) factors affect price: The fabric is one. The quality of the hardware, mainly poles is another, and to some extend the brand. Don't assume that an item is better made just because it is the most expensive option.
so that's what those long poles on the hard top are for!I borrowed this from FB. Looks simple enough. Use ball bungee's to attach to the outriggers.
This is exactly what I am looking for. More specifics on what you have?I have about $80-90.00 into this shade. Shade and poles are from Amazon, I added pvc pipe to bottom of poles so they would fit in rod holders better and added a few grommets to the shade. I leave it up all week while gone just lower the poles all the way down. So far super happy with it.
View attachment 21965View attachment 21966
These are the poles I ordered but looks like they are not available right now and the shade also, since you have a 330 you would need a larger size but should be able to find one that works. Plenty of them on Amazon in different sizes and colors to pick from. I also got some nylon webbing straps with plastic adjustable buckles to attach the front side to the hardtop tubes. I got that stuff at a local Ace Hardware store. Like I said I did add grommets which go over the stem on top of pole so the shade stays tight and does not sag. I have actually traveled along at about 15 mph with it up with no problem. I will get pics of the bottom of poles that I added the pvc this weekend and post them for you. I feel these shades are better than the canvas once because they are lighter, will store up in a smaller package and do better with the heat transfer. Hope this helps any other questions just ask and I will answer.This is exactly what I am looking for. More specifics on what you have?
