- Aug 15, 2017
- Jamaica Bay, NY
- Offshore
Hello All.......I have a 1982 24 Offshore and on my last few ocean fishing trips I noticed I was getting a lot of water in the bilge. It was not happening in the bay or at the dock.....only while drifting in moderate seas on the ocean. I finally tracked the problem to a missing drain hose from the port side fishbox to the thru hull fitting....which sits 2 inches or so above the waterline. There is absolutely no way to replace this line without cutting an access hole ....and I don't want to do that until after I pull the boat for the season.
I plugged the fitting with an expandable drain plug coated in silicone, from the outside as a temporary measure.....it seems to be holding fine but I am not too thrilled with the idea. Does anybody know of a better fix to get me to 11/15 or so when I usually pull the boat? I would appreciate any input.
Thanks,
Joe
Thanks,
Joe
