Does any one have any advice on trailer bearings?? I am in fresh water only. My trailer has grease fittings right in the end of the axles. You pull a little rubber plug and grease these fittings. Today I pulled my wheels only to find chunks of grease around the inside of the rim on all four wheels. I was told to pump grease into the fitting until it started to come out the dust cap hole and then replace the rubber cap. Can't understand why it came out of my grease seals, the seals are a double lip deal made for this type of set up ( putting grease in the end of the Axel) Has any one had any experience with this type of bearings and seals or had any problems.
