- Feb 24, 2022
- Age
- 39
- Gulfstream
Hi folks, I noticed the 1/2" bilge drain plug threading further and further into the transom drain fitting on my 1991 23 Gulfstream so I got down where I could get a closer look and discovered it out of round. Seems the stuff draining out of the bilge has been a bit caustic to the brass fitting over the ~30+ years. So I removed the drain fitting intent on replacing it with the same size part so I don't have to drill additional holes, but I am having difficulties finding a brass fitting with the same outside dimension of 2.125"... everything I find is 2.00", except the nylon stuff. Does anyone know where/what I am looking for in brass/bronze? I'm hesitant to install the nylon parts... would you? TIA, Larry
