- Mar 7, 2018
- Age
- 67
- Miss Gulf Coast
- Freedom 205
Man I was thinking my new Grady sure is watertight when I would remove the plug and no water would drain out. The other day I removed the deck access covers and noticed quite a bit of water in the bilge at amidships but none towards the stern. OK I did a big DUH, seeing the variable deadrise causes this condition. I even raised the trailer jack as high as it would go and it still wouldn't drain so I got my floor jack out with a wooden block to finally get it high enough to drain. Hard to determine how much water drained out but it was well over five gallons. I guess most of the water came from the anchor locker because I always rinse after each use and it looks to drain in the bilge. Anyway something good to know, before I put the boat up I will park on a steep incline to drain.
