Water tank sending unit 330 Express
usmm1234
Myrtle Beach SC
Anyone familiar with this sending unit? It’s probably original from 2002. Need to find a replacement. 10B3C805-2464-46AC-B578-2191857ADE2B.jpeg
Bayhouse
See my other post, check the wires to the gauge first. Might even want to check continuity from gauge to sending unit.
usmm1234
Myrtle Beach SC
That’s a good idea since I’ve had 2 other broken wires in the harness since I bought the boat. Forward bilge pump switch and hardtop speaker wire.
wspitler
Inglis, FL
Easy to check the sending unit. Pull it out and read resistance as you run the slide up and down.
usmm1234
Myrtle Beach SC
Im not sure how to remove the sender. It does not have the usual 4 or 5 screws holding it down. I assume it screws out, but I dont want to break anything.
It might just be a push in fit. Try a little twist and a tug.
May I ask, is your indication an actual level of just a full/empty type of signal.
usmm1234
Myrtle Beach SC
It a traditional analog gauge with the needle
O, got it. I asked because I did some searching and there are different types of fresh water sensors; Full range like a fuel sender and reed switch which indicate certain defined levels like full and low.
usmm1234
Myrtle Beach SC
Okay. You guys like Happy Endings? I crawled back across my gen set to try to remove the sender. I put a pair of channel locks on the square blue cap on the top of the sender. It does screw out. In order to do that. I went to disconnect the none waterproof spade connectors. When I did. They crumbled. They were severely corroded and the wires had a lot of corrosion wicking. I’m going to have to go back in and replace all the wire where the corrosion has gotten between the copper and the insulation (Wicking).
But for the time being. I cut out the connectors and some of the bad wire and reconnected them with waterproof heat shrink butt splices. Boom! My water gauge works perfect.
Ive attached pictures.2848ED23-6B57-4F4B-BCC6-D23F77B46F11.jpeg58F4B012-68DB-4EA8-8277-1A8C4EF1012D.jpeg29500F97-3AEC-4426-910E-991404AA1E4A.jpeg1F5865ED-E0B1-4555-957D-672CCB4FCF3C.jpeg
jip40
Atlanta / Carrabelle, FL
USMM - thanks for your knowledge & your reporting - life is getting easier - hope you continue to have the same problems I do - keep up the good work
Reactions: usmm1234
Aquanut2
Beaufort NC
Having a similar problem on my 04 300 Marlin checked the gauge by shorting black to blue it read full looked at the sender and it completely fell apart any idea where to find a replacement? There is a number on the blue plastic cap WU-15 83 think the tank holds 32 gals in the GW parts manual I found 19-137 Sending Unit Water Tank 15” but not sure who the OEM is & where to buy one.
Aquanut2
Beaufort NC
Just so others searching for this sender can find it thought I would share the part source. It's made by KUA Model S3U Sender it has a 1.25″ BSP Mount - 15" × 1 Looks like it is all SS now with no plastic blue cap.
Reactions: Meanwhile
Meanwhile
Warren, OR
Thanks for the info. On my Marlin I have the same setup. How did you access the back of the display? Mine is located in the head on a solid wall. I need to dig in but thought you could save me time.
Aquanut2
Beaufort NC
Take the small angled starboard off where the panel wall meets the ceiling its pain to reach but u can unthread the large back nut that holds the gauge to the wall. I could not get to the connector but there was enough wire to pull it out from the wall.
Meanwhile
Warren, OR
Thanks so much. Feedback like this is why this site is so valuable.
Aquanut2
Beaufort NC
Before you dig into the display side remove the connector at the sender and short the 2 pins if the gauge reads full then you'll know the display is fine and the sender needs to be replaced. BTW you have to turn on your water pressure switch to supply power to the tank indicator.
Meanwhile
Warren, OR
Thanks for that tip. I'll do thar.
