Re: why respace engines when repowering from 2 stroke to 4 s
No Regrets, let me clarify.
By the way where did you take the measurements from ?
Anyway, all twins traditionally are supposed to be mounted close to eachother to the dimensions I stated, if so, a Yamaha F (not Suzuki) on a 2 stroke repowering job requires reboring to new dimensions above. You don't have to do anything with a Suzie incl 300HP since no one would have bored less than 26 inches.
The reason for keeping them close (as possible) is what may happen on fast power-on sharp turns, the outer (turn) motor may cavitate and loose bite since the boat is pivoting on it's keel. Being closer mitigates the possibility. If spreading them out gives benefit say to improved throttle steering, then it's a trade off (as usual). As far as tracking during a white water troll, can't say if it matters, what does matter is counter rotators, in a big way.
Something else occurred when the first 33X appeared many years ago with the F225s because Yamaha was dragging their can on the F350, those small V6 motors in twins looked proportionally tiny on the transom, being further apart made them look somewhat better. The F350s on twins saved that one !
I see the Marlin at the shows with the F250s opened up a bit.
As was stated, contact Grady HQ and ask why. Report back here.
And you may need a new steering tie rod which isn't as cheap as it looks, will need it for V6 Fs anyway, not other brands of V6 4 strokes.
The 32 inch dimension may have something to do with the F350 which is a huge motor, with a huge 6 bolt bracket. Perhaps for ants-in-the-pants 4 stroke V6 guys going to V8s later?
Whenever backing down, outboards (especially bracketed and flat bottom euros) are best to tilt motor up a bit so the flow doesn't hit the transom but goes under hull.
The Suzies look perfect back there.
