- Oct 18, 2013
- Age
- 65
- Farmingdale NJ
- Overnighter
In earlier posts I showed how wasted the fuel lines were in my new to me '87 Overnighter 20.
I covered the boat for the winter and have been waiting for the weather to break since. This week figuring that we'd seen the last of the snow I pulled the cover off and went to work. The plan was to replace all the fuel lines and get a good look at the tank to make sure I could be confident it wouldn't leak.
Heres a familiar shot of the fill and sender lines. They didn't come out easily as it is impossibly tight where they connect.
Below is the vent hose which is doubled back on itself showing how swollen part of the hose that lay on the tank had become.
Nothing came easy on this project and I was very tempted to forgo removing the boards securing the tank and just replace the hoses with new. After all I had no sign of gas in the bilge. :roll:
I've had a tank leak on another boat I've owned and I had about 20 gallons of gas in the bilge, not good.
So I pressed on. First board removed and I had my answer...
A close up...
Removing the other boards produced two more holes. I didn't bother scraping the crud away, whats the point right?
There's no getting around it, I'll be replacing the tank.
All the bracing boards are out now and I've measured the tank. :uhm Ok, the tank is one inch longer and wider than the opening above it.
Like I said I had to fight to get to the point I'm at right now and though I knew that I might have had to replace the tank, having become a reality I'm not real happy so I've packed it in for the day. I'm not in a good frame of mind to tackle this puzzle right now.
Oh and ya, the hatch cover is going to need re-coring as its wet inside. :bang
Ok back to the tank problem. Its pretty snug in there. I'm assuming, ...no I'm hoping that its one of those tilt it and lift out by one end while knocking three times and waving a dead cat over it things. (ya sorry, I'm a little over tired right now)
Has anyone here that has removed one of these tanks have any tricks to share.
This thing is like a 65 gallon Rubick's cube to me right now and I'd really appreciate a little help.
Thanks, Mike.
A close up...
Thanks, Mike.
