Hello Gents,
I just dragged my pop's boat 1365 miles to the Keys and I can't get the engine to start..which is very odd for this motor. As I do every year when I tow it down here for dad, I hooked up the battery, hooked up and the water and hit the key....for 6 years it has fired right up..I checked to make sure all the wires were hooked up, removed the fuel filter and filled it up with fuel and replaced the spark plugs. I checked a plug on each side of the engine and stuck one of the old plugs into a wire and I had spark when turning the engine over. There is fuel in the clear bowl and I can hear the electric fuel pump turn on when I turn the key....I am kind of stumped as it was running fine when we winterized the engine in November. The only thing we did different was the take off the main fuel filter under to cowling and dump the dirt out of it. I think I had the engine running after that while I was spraying fogging oil in the carbs......any help would be appreciated as I am only down here in Marathon for 5 days then fly back to NJ for 2 months.....
