2004 Sailfish Vent Window
Legend
Southern New England
Has anyone with replaced the side window vents recently. Grady does not have them. I could not find a replacement manufacturer to produce one. Thanks in advance for any tips
leeccoll
Reno NV
Hi Legend,
Maybe this can be helpful. It will cost dearly.... George at Marine Glass Specialties in FL.
Update-Called Taylor Made, and then called Grady to get the part number. The boat is too old so there was no way for Taylor to locate the exact parts I need, but the person I spoke with referred me to George at Marine Glass Specialties in Florida. They bought a lot of older Grady Parts from Taylor.
Phone numbers for who ever needs them down the road:
Taylor Made (518) 773-0636
Marine Glass Specialties (813) 926-3717
George knew exactly what I need. The price is extremely steep, but I still will go ahead and order the new glass, hinge, and vent pull from him.
Legend
Hi Legend,
Thanks Leecoll, , I will give George a call at Marine Glass tomorrow.
Reactions: leeccoll
Greyduk
Alabama
Legend, I replaced the vent window in my 248 when I got it. I ended up with an extra piece of glass. I have had it for sale in the classified section. In the ad it shows the dimensions of the piece of glass. Take a look and if it will do for your application we can work out a deal.
Legend
Greyduk,
I saw that and thought the same thing. I took your diagram and measured it against my other window and it is a smaller window than what I need. I thought I got lucky with it. Thanks for the tip though.
Greyduk
Alabama
Legend, for whatever it's worth I had the piece of glass made at a local glass company. I removed the glass from the side that was not broken and used it as the pattern. I'm sure you will find a solution. Good luck.
Maybe check a few auto glass guys, they may be able to do something or at least make a recommendation?
Legend
Thanks everyone, Ended up doing what Greyduc did, usied the other window as a template and then had a fabricator recreate it from a digital template. Still not cheap though, cost $295 for a small vent window!
Reactions: leeccoll
leeccoll
Reno NV
AKA "Safety Glass :eek:
Good stuff Legend!
