2005 seafarer bang plate
Summertop511
NJ
Ok got my new vinyl replacement for the aluminum bang plate on my 05 seafarer. My question is, is that it’s thicker and don’t want the motor to crush it. Should I notch the bang plate or file down the motor bracket a little?
Greyduk
Alabama
Did you get that from Grady? Do you mind if I ask the cost. This may be something that I need to go to. Thanks.
Summertop511
NJ
Yeah got it from Grady. Was pretty cheap. $3 a foot and bought the gradywhite color silicon caulk to put around it after I 5200 the fiberglass underneath.
SeaVee
I e-mailed GW customer service to get a replacement but never heard back. Guess I will give them a ring instead.
I'd look at a new boat if you can. I'd be inclined to cut the cap. I'd first do a quick fit check and clamp the motor down unless the interference was bad.
