265 Live Well and salt water wash down
Lucky13
This past weekend my love well and salt water wash down stopped working. No funny sound or anything so thinking it may be a fuse. Does anyone know where the mainn fuse panel is and also where the pump that runs both of these would be located?
MixinItUp
Does the 265 not have the push button breaker's right above the respective rocker switch(es)? That is the design of my 2006 228 and my old 2001 228. Those have to be replaced from time to time. They can be easily tested by removing the panel.
MixinItUp
Savannah
drbatts
CT
both pumps are located under the rear deck panel next to there respective seacocks. To replace them will involve unscrewing and pulling up the panel then re-caulking it. If you really hate yourself you can try swapping them out through the small access hole provided, but good luck. The fuse panel is located under the dash panel on the starboard side where the Yamaha gauges are. There should be separate fuses for each pump. I find I get about 2 years out of each pump before I have to replace them. Access to them is a real pita. there is another member on here who has put a hinge and gasket on the rear deck panel to make access easier. Hope this helps. you can also download the owners manual from the Grady site which has some more info including plumbing and wiring diagrams.
max366
Here's the Grady fuse info and their location- I would have sent the pdf but the site doesn't allow uploading them.
ACCESSORY WIRING COLOR CODE AND FUSE/BREAKER SIZE CHART
ACCESSORY WIRE SIZE / COLOR AMP LOCATION
LIGHTS
BOW LIGHT 16 GA. GRAY ACCESSORY PANEL
AFT POLE LIGHT 16 GA GRAY/WHITE ACCESSORY PANEL
MAST LIGHT 16 GA GRAY/RED ACCESSORY PANEL
PANEL LIGHTS 16 GA DARK BLUE ACCESSORY PANEL
CABIN LIGHTS 16 GA BLUE/GREEN 10.0 FUSE BLOCK / AC/DC PANEL
LIVEWELL LIGHT 16 GA. BLU/RED w/ LIVEWELL PUMP ACCESSORY PANEL
COCKPIT LIGHTS 16 GA BLU/YEL 10.0 ACCESSORY PANEL
SPREADER LIGHTS 14 GA DARK BLUE/WHITE 10.0 HARDTOP / T-TOP
FUSE BLOCK
PUMPS
BILGE PUMP (FORWARD):
ATTWOOD 1250 16 GA BROWN/BLACK 4.0 ACCESSORY PANEL
AUTO FLOAT SWITCH (FORWARD) 16 GA BROWN/RED 4.0
BILGE PUMP (AFT):
ATTWOOD 1700 16 GA BROWN 10.0 ACCESSORY PANEL
AUTO FLOAT SWITCH (AFT) 16 GA BROWN/WHITE 10.0
SHOWER SUMP PUMP (FLOAT SWITCH) 16 GA BROWN/ORANGE 3.0 FUSE BLOCK / 282 ACCY PANEL
WATER PRESSURE PUMP (CABIN SHOWER) 12 GA ORANGE/BLUE 15.0 ACCESSORY PANEL
WATER PRESSURE PUMP 16 GA ORANGE/BLUE 5.0 ACCESSORY PANEL
WASHDOWN PUMP 12 GA ORANGE/BROWN 15.0 ACCESSORY PANEL
LIVEWELL PUMP
RULE 700 GPH 16 GA ORANGE/BROWN 5.0 ACCESSORY PANEL
RULE 1100 GPH 16 GA ORANGE/BROWN 6.0 ACCESSORY PANEL
IN-LINE MACERATOR PUMP 10 GA ORANGE/GRAY 20.0 ACCESSORY PANEL
HEAD PUMP (ELECTRIC) 10 GA RED/GRAY OR RED 25.0 FUSE BLOCK
MACERATOR PUMP (MARINE HEAD) 10 GA ORG/GRY 25.0 ACCESSORY PANEL
MISCELLANEOUS
HORN 12 GA ORANGE/WHITE 10.0 ACCESSORY PANEL
WINDSHIELD WIPER (ACTUATOR):
STARBOARD 16 GA ORANGE/BLACK SINGLE 5.0 ACCESSORY PANEL
PORT 16 GA ORANGE/GREEN DUAL 10.0 ACCESSORY PANEL
WINDSHIELD WIPER (POSITION) 16 GA ORANGE
ACCESSORY GROUNDS (BRANCH) 16 GA BLACK N/A
ACCESSORY GROUNDS (MAINS) 6 OR 10 GA BLACK N/A
HYDRAULIC TRIM TABS 14 GA ORG. 20.0 FUSE BLOCK
MAIN FUEL TANK (SENDER) 16 GA PINK N/A ACCESSORY PANEL
AUXILIARY FUEL TANK (SENDER) 16 GA PINK/WHITE N/A ACCESSORY PANEL
ACCESSORY PANEL POWER LEAD 6 OR 10 GA RED 40.0 CIRCUIT BREAKER
NEAR BATTERY / BATTERY BOX
VHF (HARDTOP RADIO BOX) POWER LEAD 10 GA RED/WHITE 10.0 IN-LINE NEAR BATTERY
VHF GROUND 10 GA BLACK/WHITE N/A
12 VOLT ACCESSORY OUTLET 10 GA RED/ORG 15.0 FUSE BLOCK
MEMORY WIRE 16 GA RED/PINK 10.0 NEAR BATTERY / BATTERY BOX
OIL SENDER (STBD) 16 GA LT. BLUE N/A
OIL SENDER (PORT) 16 GA LT. BLUE/WHITE N/A
FUEL GROUNDS 16 GA GREEN N/A
eppem
Trumbull, CT
That was me (hinge in aft deck). Cost me a ton but the glass work looks great and the ez of access is huge. I am swapping those pumps out frequently too. I use my livewell a ton and it just craps out - a 40 dollar part.
The washdown gets used a lot too but i think the saltwater eats away at it. I did figure out how to make an attachment and will flush it with freshwater / saltaway when i can.
I bough my last washdowbn pump from west marine and got the extended warranty - already swapped in a bad one and walked out with a new pump.
