- Jan 31, 2005
I’d like to swap out the drain lines and install the new style scupper drains on my Marlin during layup.
I’d like to cut an 8 inch hole on the interior sides of the eurotransom. On the starboard side this would be just behind where the aft door rests when open above the scuppers for best access. I plan to install an 8 inch Becksom screw in plate when done.
Has anyone done this?
How thick is the glass in this area?
Is there sufficient access to allow removal and installation of new hoses on the thruhulls on both sides?
As I recall, I can access the floor drains on the starboard side thru the aft deck plate - after removal. Should be ok on this side.
I don’t believe there is access to the port side drains. I think I need to remove the battery switch panel and then will have access. Can anyone that did this work answer questions and if this is possible to do this way. Finally open to any other ideas folks have.
