ROBERTH said:Replaced all my Thru Hulls and Hoses and the 90 Degree drain fitting as well. For me, was pretty easy to get to on the older sailfish model design. Just removed the back panel that goes across the entire back and everything was accessible. The hoses were not that bad of shape for their age, but I was mostly after replacing the plastic Thru Hulls with SS since I trailer. The deck drains were not possible to get since Grady basically took a straight threaded flush plastic drain and cut the threads shorter and then put on a 90 degree threaded hose barb fitting since no one apparently made a complete fitting like this back in those years. But they sent me new one's that are all one piece that I installed. Gained a bit of angle with the new ones for better draining.
Good luck as I know accessing some of these areas on the newer models is very difficult.
ROBERTH said:I had contacted my dealer and explained what I was looking for. He talked to Grady and they explained that back then, no one made the proper type fitting, so they made one from a flush straight sink drain type that was threaded and cut the threads, then added a 90 degree fitting threaded on to the hose. It worked well for them all these years.
Now, on the newer boats, someone is making a one piece with 90 degree hose barb. So I placed the order for them and they were very cheap. I installed them and they worked perfectly. Being a one piece system, they probably gave me about a 1/2 to 3/4" rise in the hose angle which is always an improvement.
ROBERTH said:Found my old email where I ordered. You might check if this part number will fit your boat:
> Here are the prices you asked for from Grady White:
> Part #: 11-369 $ 1.50 ea. QTY = 4 for Floor Drains.
Also, I had the Grady Dealer Drop ship them to me so I didn't have to drive 200 miles to pick them up.
For those still looking to change the drain hoses:
I recently just cut the hole on the starboard side for a 98 Grady White Islander. The location in this post was spot on. I used a Beckson 10" deck plate with 8.5" hole. I am not familiar with Armstrong plates but it sounds like those could stick up from the floor just a bit. Use caution bc I don't know if the transom door would rub on something else that sticks up higher. You can see that the 20 year old drain hoses have just about reached their limit. Here are some photos!View attachment 6823
