Edson Steering knob
Grady White Guy
Has anyone installed one of these on their wheels? Does it fit with the metal band or do you need to drill a hole through wheel?
wahoo33417
West Palm Beach, FL
Metal band worked for me, but had to add a bit of 'lok-tite' to the threads to stop it from working loose over time. Would not be easy to drill a straight hole through the rounded surface of the steel wheel.
GW uses a Schmidt wheel. I changed one out on an earlier boat. They offer it without and with the integrated ball.
You could swap out the stock wheel for less than a couple of hundred (bet you could do better than the prices here if you shop around) and sell your existing one on ebay.
http://www.go2marine.com/product/92598F ... ision.html
SC Adventure 208
Make sure you put it at 6-oclock position when you are going straight. The added weight tends to pull down there and if it's not at 6 then boat will steer off course.
drbatts
CT
I put and Edson knob on about 5-6 years ago. no problems.
Enough Already
Boca Raton, FL USA
No matter what position I put it on, it always seems to end up at the 6 o'clock position just when I hit a wave and fall forward.
CatTwentyTwo
Los Gatos, CA
I had the same problem with the all stainless knob. I sold it and installed the one that is lighter and made mostly of a polymer material and I like this one much better. It doesn't have nearly as much effect on the steering.
onoahimahi
Boston MA
Ouch... :cry:
