Finally wet!
Chessie246G
Maryland
Damn near killed myself getting it ready the past few weeks. But all worth it. In the chesapeake bay with 15 to 20mph winds. Handled like a dream! Only 1 hiccup! Reserve oil tank pump quit pumping.. had to refill the engine mounted tank twice on the way back.
kirk a
Massachusetts
Always so great to get that first boat ride of the year. That sense of freedom as the last line is tossed, and you move away from the shore...
Chessie246G
Maryland
Honestly it was terrifying. LOL engine running like crap (smoothed right out after 5 mins) Rough water conditions in an untested boat.... but all in all it was great first trip.
There is a toggle switch in the motor that can run the oil pump to fill the small tank.
If I were you I would bite the bullet, remove the big oil tank, drain it, clean it, replace the little white inline filter and the rusty pump and whatever brittle or gooey tubing you find.
Be glad you only have one.
Chessie246G
Maryland
Toggle switch had no effect. I surprising knew about that one. Pump made no noise. Already ordered a new pump and filter. Going to test the wiring (didnt have my multimeter with me) but Im pretty sure its a pump issue.
blindmullet
Florida
I have a NOS one in my garage if you haven't ordered the transfer pump yet.
Ryhlick
Congrats! Make sure you clean the intake screen on the pickup inside the tank. Also, on the backside bottom of the reservoir, there is an inline filter that can get clogged as well. Good Luck
Reactions: Chessie246G
Chessie246G
Maryland
Ordered the inline filter.
Reactions: Ryhlick
