- Apr 20, 2017
- Age
- 67
This is my fifth Grady White and my first 2017EXPRESS 370. She is a beauty that I bought last year but have never extended the SunShade except for 1/2 inch bump at the time. Obviously, because it took 30+ minutes to extend the shade, it didn't get used much. Our boat buddies, with a 330 Express had the exact same issue. This week while on an extended trip around the Chesapeake, we had time to study the problem. It turns out the SureShade gets its motor power circuit from a dashboard circuit breaker (switch power is separate). The line of circuit breakers is feed 12v from the left hand end and power is daisy-chained across the panel. A test light showed that the shade was pulling the voltage down halfway across the daisy chain, which at that point the voltage didn't vary. Pulled the loop of wire off of the panel between circuit breaker 4 and 5, cleaned the terminals and we are now 100%. We found the same solution on the 2016 330. Hope this helps someone who has a similar failure. BTW, all of my functions downline from this poor electrical joint started performing much better (especially the sunroof).
