Gulfsteam 232
Patch
I am considering buying a used 232. Was there a significant design change between 2005 and 2006?
SlimJim
Somewhere on here you can get a link that has the catalog and manuals for both, download them and compare.
Gman25
Bayshore, NY
There were quite a few changes in 06. The main ones I recall were the new style transum fish box on the 06, the new style pulpit on the 06, a helm change on the 06 and some changes in the cabin.
2005 300 Marlin w/F250's
Patch
Thanks for your reply. Was the beam the same pre 2006?
Patch
Slim Jim, Thanks. I found the place to look at past years.
Legend
Southern New England
The beam did not change. I personaly do not like the change made to 05 -07 models with the transom bench seat being replace with a fold away one. There were also some changes to the cabin layout with the head
Patch
Looks like there are a lot of "head options" for the 232. It it a simple matter of getting what you pay for or is there a choice that works better that the rest? Is there a "must have" choice? I have had a 36' Shannon Voyager in the past with a fancy Vacuflush head but would not have another as they are very high maintainence. Right now I have a 26' Duffey lobster yacht with a manual flush head.
Gman25
Bayshore, NY
What kind of high maintainence are you talking about?
Patch
They are actually a great machine and run with fresh water so there is no oder. But,If you have had one you would understand. If you have not, a good rule to post on it is "if you have not eaten it don't put it in here"! If you have people aboard who are not careful, you will spend a lot of time un-sticking pumps.
Gman25
Bayshore, NY
Guess I've been lucky..2 years without an issue.
Patch
Congratulations! Probably not just luck. You most likley run a good boat and carry thinking passangers. Seriously, after we figured it out the Vacuflush worked fine the last few years we had the boat.
Gman25
Bayshore, NY
Patch, what were you doing that was causing all of your problems?
Patch
It was in a 36' Shannon Voayager trawler that we cruised from Texas to Maine. We took aboard several groups of friends as we went along. Probably people were putting in too much paper and even paper towels that clogged the pumps. The last two or three years we had no problems.
NIGHTIDES
Glad to see someone else did not like the transom bench change... I think it was a disappointing change to an otherwise well designed hull.
GWcpa
Richmond, Northern neck VA
Interesting comments about the new cap design. I had a 2001 with the rear bench. Access to the bilge and ability to get a rod around the engines was better with the previous design, but otherwise the huge new fishbox is a big plus. I like the flip down seat as well.
I am sure it would be easier to get to the swim platform with the older design as well. Otherwise I do not know what the objections would be. I like the new helm and cabin layout as well.
I do remember looking at the new design and thinking that adding a transducer or changing a pump would be tough with the limited access.
