How To Winterize AC System?
RobboNJ
LBI NJ
I have been winterizing my boat the last few days, and now need to address the AC/Heat system. Unfortunately, I am clueless on how to do this. I believe this is a self-contained system, and water is drawn in through a seacock. But how do I flush it out, or circulate antifreeze through it? Any help is appreciated. Boat is a 2008 Sailfish 282 with factory AC.
jap201
on our old tiara, there was a sea strainer after the seacock. Open the sea strainer, start the a/c and pour antifreeze into it until it's spitting pink (or purple) from the output. If you don't have a sea strainer, you might be able to put a 'T' into the line with a hose connector to feed it antifreeze.
Reactions: Late Again Grady
Another option...
Get a cheap hand pump and put one end in a jug of antifreeze and the other end... jamb it into the A/C thru hull exit fitting on the side of the boat. With the seacock open, pump antifreeze in till you see it come out the pickup on the bottom of the boat.
RobboNJ
LBI NJ
Dennis, you're proposing a reverse flush. I like the simplicity of it, will the flush get through whatever pump is in the middle?
drbatts
CT
Backflushing through the outlet with antifreeze is the way to go. Simple and easy with a water pump. I usually run 2 gallons of antifreeze through on my 305.
teaklejr
Open strainer, turn ac on, pour into strainer till it comes out side of boat, turn ac off then put strainer cap back on. No need for a extra tool to do the job. You do need 2 people to do it, one to pour and one to turn ac on and off.
Yes. That's why you'll see it come out of the thru hull on the bottom of the boat ;)
The A/C is basically just one long tube. Both ways work equally well.
RobboNJ
LBI NJ
So I was able to open the strainer and fill it with antifreeze, but it stopped pumping out the side. I think I have a blockage in the pump or it got air locked. Next step is the reverse flush. I can buy a drill pump for $12 so not a big expense.
If you need to, add tape to the hose till it fits snugly into the hole in the side of the hull.
RobboNJ
LBI NJ
I plan to use a hose with a tepered rubber stopper on it. Hopefully that will seal the drain hole and all the antifreeze will get pushed out the thru hull in the stern. I am traveling for a week so will post updates after I return.
eppem
Trumbull, CT
Reverse flush has worked for us on our Marlin, it just depends how the system is laid out. I have tried the first method of adding "pinkstuff" into the line with the unit on and it didnt work. In order to get reverse to work, at least for us, you need to make room for the pink to push anything out of the line. As simple as opening up the seacock and pulling water out the seastrainer with a turkey baster. Use a funnel into the discharge line and pour the pink stuff in, no pump needed! If you hearing or see it pouring out of the inlet and onto the ground, you are done! If you are on instagram, check out @lisboatingandfishing - there are some pictures.
RobboNJ
LBI NJ
Got back to completing the winterization today. Bought a Drill Pump "Kit" at HD for $20 and it worked great. The hose attachment that comes with the pump fits perfectly and snuggly (as in no leaks!) into the thru hull fitting for the AC discharge. Put the intake end of the pump into a gallon jug of pink antifreeze. Opened the seacock and started the drill. Immediately saw the level on the jug going down and after 10 or 20 seconds had pink coming out of the bottom thru hull pickup. Let it run for a bit longer and turned it off. Mission accomplished! Thanks again to all for your advice and instructions!
RobboNJ
LBI NJ
Once I had good advice and the right tools it was a piece of cake! Thanks for your info!
eppem
Trumbull, CT
On our Marlin we suck the salt water out of the sea strainer with a baster and literally pour pink stuff in the discharge with a funnel. Ezpz!!
