Need help identifying transducer
SecondWind282
Charleston SC
I have a 2001 282 Sailfish with the Raymarine e80, DSM300 sounder module. I need to know the transducer model number to have proper settings on the e80. It appears to be the original thru hull style, its the pointed oval shape and has the spinning speed sensor.
Does anyone happen to know what model this might be?
Halfhitch
Venice, Florida
There should be a tag with that info on the cable near the end of the cable where it connects to your MFD. If there was an extension cable used to reach your helm, then look for the tag near the connection with the extender.
SecondWind282
Charleston SC
Thank you! I'll give that a try
transfib
If for some reason you decide to go with a transom mount transducer it's an Airmar P66, Raymarine number E66054.
