My forward bilge pump float switch on my 330 was not working. I first thought it was the breaker. It was not tripped. So then I assumed the switch was bad.
I cut wires to float switch and touched them together still no pump. What I found from the battery switch box/breakers about three feet down is a plug from the wires going to a harness. The wires/plug were all corroded so no connection. I removed the plug and just used a butt connector to put back together. All work fine now. Hope this saves somebody some time troubleshooting.
