Re: Opinions on Penn setups is this , deal I can't pass up?
That sounds like a fantastic deal. I would snap those up in a heartbeat. When I lived in the Marshall Islands 10-years ago, I used to run two 50 two-speeds, two 80 one-speeds, and a 130 one-speed (and an old 12/0 which had my favorite clicker!) With the Penn two-speeds, I never really felt I could use the low gear unless the fish was down deep under the boat. If it was out behind the boat, and I shifted to low gear, it would never fail that the fish would turn around and charge the boat and I wouldn't be able to keep up in low gear. The earlier Penn's were difficult to shift from low-to-high in the heat of the moment when the fish was charging. I always thought they designed that backwards - they made it easy to shift from high to low, just press the button. However when shifting from high to low, you have all the time in the world to shift. When shifting from low to high, you have to press the button and pull the handle at the same time, which, in the heat to the moment when your are cranking as fast as you can, is hard to do IMHO. The newer ones shift better - more like the Tiagras. I prefer Penn's to Shimanos mainly because I do not like to add to our trade deficit when I don't have to. That is another reason why I love my E-TECS... :wink:
-Scott
