Power tilt and trim needed
Nomadicdeaner
I’m Looking for a Yamaha power tilt and trim unit for a 200-300hp motor around mid 2000’s era. I’m in Canada, Lake Ontario area. If yours looks like the pictures I’ve shared and works please contact me.F2924CE8-7B6D-4D71-BE89-579AFC8022D5.jpeg8FDD6041-2E04-440E-9223-6081D6DB9687.jpegDB332B46-31D1-44C9-B2A4-4AECA96E0E51.jpeg8FDD6041-2E04-440E-9223-6081D6DB9687.jpeg I’m
Hard to find new and very expensive. Used are out there
For example
It's a crap shoot though. You don't know exactly what you are buying
If your is just leaking, there is a company that will rebuild it, assuming it is rebuildable
Nomadicdeaner
For example
I cross threaded one of the flared tubes in the housing. It’s at a machine shop being repaired. The next option is finding a used one if the shop can’t fix it.
Without telling us what the fix was?
mhinch
With a stripped out gland this could be a tough fix. Easy enough to re-pack the seals. Did mine in an afternoon.
Nomadicdeaner
The fix was, I took the trim unit to my local Hydraulic repair shop and they installed a 1/4NPT to 3/16 compression fitting. See picture below.
mhinch
Easy fixes are the ones we like. Good for you. Thx for closing the loop
