- Sep 26, 2009
- Massachusetts
- Express 330
Need to replace the shore power connector on the boat - the male portion. Took a quick look at the existing Furrion connector and have a new one in hand. However, the back half of the plug receptacle will not fit through the hole in the transom, and there are no obvious access points in side that portion of gunnel. Additionally, it would be a ridiculous reach from under the floor/bilge area. I pulled the coaming pads off as well, and nothing there. Under the gunnel has nothing either. Any advice would be great.
Effectively, there is not enough scope in the wire to pull the external part away from the transom enough to access the wires.
Love the simple jobs that only involve removing and replacing half a dozen screws that turn out to be day long due to access issues.
