Replacement cam latches
ROBERTH
Raleigh, NC
Anyone know where a source is for replacement cam latches that will fit on the cabin cabinet doors? One of mine just broke last weekend.20190713_124945.jpg20190713_124851.jpg
ROBERTH
Raleigh, NC
Thanks seasick, seems hard to put together one that will work. Will have to go down to boat and remove one and get measurments and see what I can do from there.
In the meantime, anyone know of any laying around or any other source in case you have had to replace them?
ROBERTH
Raleigh, NC
Thanks Len! First thing I have found that is even close to what was used. Got to do some measurements. I do wish I could find them in plastic though.
ROBERTH
Raleigh, NC
Depending on where you boat, the die cast zinc know may corrode quickly. The original plastic looks to be all plastic. The Southco is available in stainless steel but I bet it cost a pretty penny
ROBERTH
Raleigh, NC
Yes, true. Will see how it holds up. The latch part is most likely the corrosive part and might think about coating it.
Ahhhrichid02
I am looking for the exact same thing. Being that it's a couplebyears since you were, the links no longer work!
