Swim Platform
Bumpye
North Shore, Massachusetts
New owner here. First time posting (that takes care of legal)! My swim platform is "soft" on the port side on my 2003 Gulfstream. Apparently the wood core is soft due to water intrusion. I was told a new platform runs about $600 + install. I was also told you could inject an epoxy to firm it up. Has anyone had any success using the epoxy method. Thoughts?? My son and I are pretty handy so we feel we can change the swim platform ourselves.Thank you in advance for your time.
IFS88
My Marlin had the same problem in the deck and the transom, but a profesional took care of it, he replaced the wood and you cant even see the diference he did a great job!!!!!
Git Rot... Warmed or thinned epoxy... it's kinda hit or miss. Chances are, the rot area is much larger than you're expecting. Personally, I'd just skin it and rebuild as it's pretty cheap to do so. Especially if you can access the bottom side since you don't have to worry so much about how it looks. You might even be able to do without removing the platform... although it's certainly easier to do so on your workbench. You can replace it with marine ply or step up and use something like Coosa board or Divinycell and never ever have to worry about rot again. But properly done, marine ply should last many, many decades.
Bumpye
Thanks for the replies. I wasn't aware you could repair/replace the wood core. Sounds like that might be the way to go. I'll let you know how it turns out.
ROBERTH
Raleigh, NC
Bumpye, do a search on here and you will find some recore jobs several of us have done. Not a bad job. I did mine and it made a huge difference. Everyone has a different approach to it. I used Pro Balsa to keep the weight down and keep the strength. Others like to use ply and some the new tech boards.
Using epoxy is the way to go as it is much stronger, more water resistant and easier to work with as I found out.
artodea
Boston Northshore
I just completed a re-core of my swim platform. I found that you can't really just replace one portion because the moisture intrusion just permeates through everything once it starts. My materials cost was about $250 (balsa, glass, epoxy, and paint) but it came out great (I did not have to touch the top portion).
Roberth is correct - do a search as it's been done before, but his posting on THT was a great inspiration for me:
http://www.thehulltruth.com/boating...m/466098-balsa-core-lamination-procedure.html
Good luck
